Hi
Hi
Sounds like your Wifi chip has died. What version of Wi-Fi: is shown in Settings-> About
If it's 655.65 then sorry, your Wifi chip has failed and you'll need to send the watch in for repair. Almost every other post like yours where the Wifi just stops working has been a hardware fault I'm afraid.
Try several times, it will eventually work after the 3rd or 4th. For me and several others in the forum (look for other threads), the issue is similar. Garmin hasn't comment anything on that.
It all started to happen after the new FW "update" (I would call it downgrade nonethelessj
My WIFI chipset is 655.35
It does.
The only other thought might be having turned wifi off in the Battery Saver. (Apologies for pointing this out, but thought I'd mention it just in case).
Yea, sorry, 655.35 is the Wifi chipset has failed "version number". That's what I meant to type in my original reply. Sorry, you'll need to get Garmin to replace/repair your watch.
