Beta 20.51 battery Logging only
Do you work for Garmin?
					Really hard to conclude anything from this, it takes general knowledge on ARM processor power management and knowledge of the architecture of the system. See Garmin Fenix 6x Pro disassembly to get an idea…
Anybody here is in contact with the Garmin Support or Beta Team about this issue using Beta 20.51 for troubleshooting ? Garmin_ODQA / Julianna_ODQA
We have suggested to the users replying in this thread…
And
https://www8.garmin.com/support/download_details.jsp?id=15164
https://www8.garmin.com/support/download_details.jsp?id=15162
https://www8.garmin.com/support/download_details.jsp?id=15160
https://www8.garmin.com/support/download_details.jsp?id=15168
					Does this beta have the 'device usage' widget?
No not working for garmin.
I found this information here http://www.gpsinformation.net/allory/new.htm
and thought that I wanted to sharing it here.
yes,
Info from beta page
This beta update is intended for battery drain data collection only....
Is any way to see this data or only by 'device usage' widget?
					In betas that have a Device Usage widget there will be logs in \Garmin\debug named usage.log, usage_hrly.log and pwrstats.csv. All viewable text files and the last one can be easily read in a spreadsheet.
I haven't checked this for 20.51 yet though. I am still on 20.42
ok, I'll check this files. I have still draining about 50% bigger than I expect.
Hi Everyone, installed the 20.51 even if I had NO (and apparently I don't also after update) battery issues, Lucky me. But I installed this beta anyway since I though a new FW installation could solve another little thing, but nothing changed...
Description:
if I reboot my watch (both in case I turn off through quick menu or in case I force turn off by 20 sec continous press of light button) when I turn the watch back again the blu triangle appears for couple of seconds, then the watch shown the gear icon, same as when it is installing stuff, while contunuing to boot.
The progress bar below the gear icon is fully filled since the momoent it appears, and the boot happens normally, but... to memory before 20.50 this icon was not shown, the blue triangle was on screen for the whole booting time.
Asking myself... is this normal now (meaning, something was changed in the firmware and the watch is actually supposed to show the gear icon while booting) or is it only my F6, and in case... to what could this be due?
For clarity, this happens since installation of 20.50, which happened through connection to Garmin Express, while roll out was still not complete (it was to memory at 50%, so I guess my serial was in that first 50% rolled out.
It really is not a big deal as once booted up the watch works perfectly fine (though admittedly not using it heavily in these days, so unsure if any specific functions are impacted) however I am curious in reference to this strange behaviour...
thanks, cheers.
Where do I find the Usage widget please? Is that the one when you’re in the About screen and push the light button a few times
