Is there a Flashlight available for the Fenix 6X which you can open by pressing a button for a long time?
I have on my F6 pro solar, just set correctly shortcuts under System menu
Not a physical flashlight, there is. Flashlight function that basically turns display white at max backlight (i find it useful anyways for working around the house in the dark, not powerfully enough to be considered a flashlight for external use, though)
You can assign an hotkey though menu for fast turn on (like long press on down button, for instance).
Ow mine is not a 6x, it's a 6 regular size, but I think it's the same
Thanks … which onze die you download?
Nothing to be downloaded, it is a native function already present in the watch
Found it … thank you
Long press light button, should be among the quick menu items you will see there, if it's not there you can add it from the settings of the quick access menu
