Hi guys
I have an HSBC subsidiary which Garmin doesn't support. After looking around I noted people are using revolute as a third party patch Garmin says revolout is supported. So I set up an account and connect days not supported? John
Hi guys
I don't really understand your question, but I have Garmin Pay set up with a virtual Revolut Mastercard and it works.
Hi
It doesn't for me won't accept it ,although mine is visa
J
Where are you based?
Ian in UK
I have it it up and it's working.
Denmark
Thanks guys not sure what the issue is.
Definitely saying not accepted but is on the supported list ?
Same issue here, Revolut and Visa. Card OK, supported by list, Finland. Watch latest firmware.
I use Curve, which is a proxy card for loads of others. Curve is supported by Garmin and works great.
Same here. Unable to add my virtual Revolut Visa card (I've only virtual one). I've 4 others garminpay compatible cards: no problem.
Problem is from Revolut I Think. When I search, I found a lot of threads (reddit and others) speaking about Revolut virtual MC works, not VISA (BIN four first digits are differents).
I have the same problem. Mastercard seems to work but Revolut are only issue Visa cards here in Ireland
try creating a 'mastercard' virtual card in Revolut and use that, if the standard visa isn't being accepted by Garmin
