I don't live on the ground floor. But now, every night, the automatic calibration brings me down to the ground level.
Garmin, please return the calibration settings to those described in the instructions for the device
support.garmin.com/.../
Agree. I live on ground floor.. but now my watch sais I'm 93m above sea level compared to 63m.
Why change something that works? And how come I live 30m higher now?
For me this new altimeter calibration is not working at all. eezytiger like you I'm having auto calibration and sensor mode auto, before the new update my altimeter was very close even when i was traveling…
Altimeter drops to zero every night. Garmin what was wrong with manual calibration? It worked fine and I want it back!
For those with problems I wonder if it would help to manually save a location at your property with the altitude set to your preference. In theory this might/should override the DEM reference that Garmin uses for those coordinates. Maybe if you sleep many floors above ground level you could even bake in your own correction/adjustment to the DEM.
Personally my overnight calibration are close to, if not exactly matching the DEM value around my house. Yes, I sleep one floor above ground level, but I am OK with a 4m discrepancy when I understand the mechanics of the calibration function. FWIW I have also saved my own location points outside the front and back of my house, just to help solidify the numbers.
When I go for my daily dog walk the Garmin DEM shows 15m in the car park. I have saved a couple of locations in the car park set to 17m, which I believe to be more correct. The watch always seems to start out at the 17m altitude that I've saved, even if I started GPS soaking some way away on my journey to the car park.
This is all on 20.00. I'm using Auto Cal = On and Sensor Mode = Auto.
Sadly, things are still not perfect - my car elevated by 3m while parked for 45 minutes and my house sank by 16m by the time I returned home, but at least my overnight calibration and start of activity calibration are good.
I have tried several times to manually calibrate the height in my apartment on my floor. But it doesn't help, and every night something goes wrong.
Maybe it's because my workout usually starts near my house, but at ground level. It turns out that two points with different heights are very close.
For me this new altimeter calibration is not working at all. eezytiger like you I'm having auto calibration and sensor mode auto, before the new update my altimeter was very close even when i was traveling to work and back, few meters but many times spot on. Now with this new one i just go to the shop and my altimeter is all over the place. My home location is saved still the nightly calibration not working,like today woke up shows me 43m instead of 34m. Btw just tried first time nightly calibration because I have always power saver mode at night. This new auto mode is rubbish, sorry Garmin.
Several nights passed. Never once did the night auto calibration set the correct altitude. More often than not, she lowered me to ground level. But several times she lifted i into sky, above the roof.
Tonight the clock showed that I had climbed from a height of 226 meters to 620 meters. Where does the clock get these strange numbers?! Garmin, please turn off forced autocalibration. Obviously, it only makes things worse very often.
Barometer reading for the last 48 hours. Night auto-calibration and manual return.
I didn't sleep tonight and the altimeter did not automatically calibrate. This is victory!
