I have a Fenix 6X Pro, purchased in December 2019. It has been working flawlessly until I applied the North America map update 2021-20. The update was unsuccessful, and when I rebooted the watch, it went into a loop cycling between the Triangle and the Garmin logo. Initially, I was not able to perform either a Hard Reset, or a Soft Reset, but after a lot of button pushing, I was able to Hard Reset the watch to factory defaults. However, now the watch will freeze if I try to access any function beyond looking at the base watch face. If for example, I try to sync the time with GPS, the watch freezes. If I try to sync the watch with my phone, the watch freezes. After the watch freezes, i will take me several attempts to Hard Reset the watch. The Hard Reset approach I am using is:
- Turn off the watch by pressing and holding the power button
- Simultaneously press and hold the Down & Back buttons.
- Press the power button, release after the Triangle appears
- Release the Down & Back buttons after approx 30 seconds.
Note that this approach only seems to work about 20% of the time. For the rest of the time, the Hard Reset fails, and the watch goes into the Triangle/Logo loop.
I have tried this reset approach, which doesn't work, it just places the watch into the Triangle/Logo loop:
- Power down the watch.
- Power on and as soon as you see the triangle press and hold the top and bottom right together.
- Release top right on the first beep.
- Release bottom right on the second beep.
