The issue:
Position triangle suddenly stops moving when ascending relatively steep slopes (about 25 degrees and steeper). It may be stuck for 2 minutes, 20 minutes or even more. Resulting track segment is almost straight line with few points which does not reflect the actual route.
Here is the link for two tracks recorded with Fenix 6x Sapphire and GPSMAP 66i (both devices on me):
https://nakarte.me/#m=17/52.88894/93.38702&l=Otm/Wp&nktl=iXaMFWV18FyZuPJxx9QOkg
Conditions:
The watch is on the outside of my left wrist. Absolutely clear sky above, no trees and other tall obstructions around. Activity - Hike. GPS indicator shows full signal.
I have tried different GPS settings (changed sattelite systems, data recording interval) and full reset - nothing helped.
Found solutions and observations:
If I change sattelite system or perform sequence "pause - resume later - resume" during this "stuck triangle" situation, the watch almost instantly finds my correct location, not for long hovewer. Then why the watch is unable to reacquire correct position by itself?
The situation seems to be better with tall trees around.
I guessed that it has something to do with "wrong signal" refleсted from the surface, so i tried wearing the watch on the inner side of my wrist and looks like the situation is better, but it requires further testing.
In any other situation the watch performs almost flawlessly with expected GPS accuracy.
I've had this issue since firmware 4.40 and it is still there on 19.20.
I've never had such issue on my older watch - Fenix 5x.
