Tactix Delta Applied Ballistics
I’ve just purchased the Tactix Delta with AB and installed the latest updates. I’ve created a profile and sent it to the watch. I also have a Tempe connected to the watch. When i go into Environment and toggle Auto Update it changes my profiles velocity from 1650fps down to 199fps. I then turned auto update off, changed the muzzle velocity back to 1650fps. I then manually went through adjusting the environment data one at a time and isolated the issue to the temperature data. Whenever the temperature data is adjusted, it changes the muzzle velocity.
