I wasn't expecting it. I'll check to see if it fixed the temp data field in pool swim mode, thats one of the bugs I reported., well it didn't fixt that ,oh well.
official release forums.garmin.com/.../fenix-6-series---19-20-public-release
Fenix 6 Pro 19.20 Firmware (direct from Garmin):
Beware, this is for the Fenix 6 Pro and may cause problems if installed on any other version (6S or 6X). I expect the watch would recognise the firmware…
I would say that if you newbie, do not install files that don't come the official way.
Just wait a couple of days for the official update with no manual file copying.
The music problem on bluetooth is due to the BLE/ANT firmware. Backdate that (you can without harm, but then you have to turn off automatic updates or it will put it back!) to 5.04 and the problem will disappear. I've seen no negative impact from doing that.
No idea! I only had access to the gcd. Hopefully someone else will be able to provide it.
Thank you
Sensor hub 11.01 from Garmin for the Fenix 6 Pro:
p.s. This one goes in the REMOTESW folder
Thanks! For anyone else, I can confirm this updated my F6Pro's Sensor Hub to 11.01 correctly.
thank you !!!
Great stuff!!
When i try to add the main file into the watches garmin folder, i get the message cannot install and unlock watch! how do you unlock the watch once its connected to the laptop?
Thought my 6X Pro Solar charging got broken by updating to 19.20 but all I had to do was a hard shutdown then restart.
