Does anyone know if a Tactix Bravo Titanium Band will fit on a Tactix Delta?
I think that they both use 26mm bands but I think the pin on the Bravo is screwed in?
I wouldn't try it.
It is not a quickfit band. The spring bar is not screwable on the fenix 6 series. If you attach the band, you won't be able to remove it easily. You may have to destroy it or damage the watch.
Thanks for the reply.
I appreciate that its not a quick fit band but the ebay seller (who advertises as an authorised Garmin seller) seems to think that because they are both use 26mm bands that it will fit.
Anyone else have any thoughts or suggestions?
Yes, it will fit but will be near impossible to attach to your Tactix Delta and later remove it. What bluefish said is spot on.
Good forum thread to give an idea of the headache involved. Not impossible but you have to decide if you want to endure the process and possible end results.
Thanks for all the information.
Even though the Bravo titanium band is $150 cheaper than the Delta titanium band after reading that other thread and the replies on here I don't think I'l be buying one.
I also wanted to buy a black leather band and notice that Garmin don't make one. Does anyone have any recommendations for this route?
