Some bugs to report
Have had the watch for a few days and generally love it ... however I have found a few issues:
  • (13 days later) I got the goal animation for steps last night just before bed (as was trying to hit it as I always do, and even showed the animation to my partner as she was around me at the time) - so didn't do much over the goal; the following day, I check the app and it states that I was 6 steps short Disappointed
  • GPS:
    • Auto pausing an activity when stopped basically doesn't work at all; it stops the activity repeatedly even when moving (exp while walking) then takes a few (maybe 10m to reactivate it).. I think there should be options for "when stopped for 15/30/60" seconds
    • Detecting steps for walking activities should also trigger the unpause; as the GPS can take ~10 or so seconds to unpause (if I am crossing a road, I can literally walk to the other side first before it will pick up that I am moving again)!
  • Related (state not updating?):
    • If I assign a shortcut to navigation (long press start button), then if you open the golf activity, and cancel the fix and exit it; then try to enter navigation it states that "Navigation is not available in this app"... It works however if you go to it directly through the activities.
    • If you start a breath work activity and end it, then go back to the watch face, enter the settings menu > navigation > data screens and then edit Navigation fields; some field categories are missing for example Navigation
  • Sleep:
    • I work shifts so do not have a regular bed time; do not disturb when set to sleep shouldn't use fixed hours, but work out when I am asleep using the inbuilt sleep tracker.
    • The sleep tracker only tracks sleep between the hours that you set; if you sleep early it is not detected.
    • If I sleep multiple times in a day the sleep tracker doesn't seem to pick up ones outside the bedtime hours you specify
  • I can view the map, and get a fix almost instantly, but when I select "Save location" it takes ages to get a GPS fix ... I assume because it is not using Glownass or Galileo (also I think these settings should be a set 1x somewhere, and in the activity have a use system option!)
Love the watch; and purchased a top of the line one ($2K AUD); but these issues are a real pain.
Also some suggestions:
  • I have the solar edition; it would be good if the backlight could be set to "auto brightness" since it is aware of how much light there is
  • System setting for GPS type (Glownass, Galileo, etc)... and can be overwritten (as mentioned above)
Hope someone at Garmin can look into these!
Thanks,
Kris
