Hola, desde hace unos días mi Fenix 6 solar, se desconecta del Bluetooth y lo hace intermitentemente. Se apaga el símbolo de la pantalla y vuelve a conectarse. Me pueden decir cuál es el problema q tiene. Gracias
using android phone or iphone?
If android have you set your connect app to not be optimized (i.e. allow it to run in the background all the time)? Some manufacturers can make android very aggressive in killing off apps running in the background to improve battery life/performance - however if an app like Garmin connect which helps you with your watches connectivity - it can cause issues like this.
