Fenix 6x Sapphire Battery Life degradation
Hi Everybody, I guess many of you have suffered like me the frustrating experience of having your beloved watch drain the battery far faster than expected. I have searched the forums, read many of the suggestions, tried them but realised that what I wanted was to have my watch perform as it should  -- that is, I want to use BT, WiFi, Music, GPS and cover 8+ hours of weekly exercise without a worry about recharging the battery every day, but rather every 5 days or so.
So, I contacted Support, but my watch was apparently out of warranty because it was 18 months old. Then I decided that I would investigate directly and lost the fear of opening it up and take the guts out... daunting, warranty voiding and ebay-sell forfeiting.
But worth it. Here's what I did and found out.
I suspected it was the battery because I am a power user... -- I bought a replacement that came with 600mAh instead of the stock 480mAh. It did not fix the issue. I did check the current consumption and set up an external power supply and coulomb counter, and it was all in check.
I then suspected Wifi, BT or GPS silicon issues. No. All good.
In the end I think it is a matter of the Power Manager (Maxim 20303) and SW, and poor battery calibration after a SW update.
What did the trick for me was to put the original battery back, then you get various odd readings of voltage and capacity estimation, which you correct with several iterations of full reset, charge, full reset, charge, until the battery is recalibrated by the SW and the PMIC itself. I am now back to having a fully functional watch, but I had bought an Enduro and it is difficult to go back to the 6x, unless I need maps.
Hope you find this useful -- I can provide more details if anyone is interested.
  • It sounds like you have more experience with this than I do, but I have gotten in the habit of doing a soft reset after every new software installation -- hold down the power button for ~30 seconds until the watch turns off, wait ~10 seconds and then power the watch back on.
    This seems like it has fixed most of the wonky power consumption issues with my 6X. I've had my 6X Sapphire since the initial release and I still get roughly full battery life of ~60 hours GPS / 21 days smartwatch sans SpO2 / 15 days sleep-only SpO2. I am on 17.73 beta currently and battery seems fine.
  • Thanks for the reply, and glad than your unit is working fine for you… some of us are experiencing some difficulties unfortunately. I have to say that I love the Enduro
  • It seems everyone has a different "solution" for this, mine is to reboot both watch and phone a couple times after it starts becoming a battery hog after an update. But now the "I've fallen and I cant get up" alarm went off three times while running and jumping around on the beach with my niece and it said something to the effect it was going to call emergency services? ..Garmin crazy updates always seem to mess up things...
  • Yes battery drain is chaotic.
    When I'm on battery saver (mainly only the BT is off) I got great results.
    But when I leave the Blue Tooth On it is really chaotic. 17.73b has not changed it.
    Once I engage the BT between my Fenix 6 Pro and my Samsung S20 Plus, anything goes.
    I can have 1.5%/hour of battery drain. And this is not the "relative" drain of the high 90's after a charge.
    (Often on mine, it drops until 95% very fast, I consider that as a kind 'calibration'...)
    The Fenix loses that kind of amount in its 70's...
    So really I don't know what to think apart switching to Instinct Solar for a free mind ?
