Calibrate local barometer
Is it possible to calibrate the barometer that reads local pressure?
I work at a metrology institute, and when you calibrate an instrument, you work with raw local values: it makes little sense to calibrate the pressure at sea level (you don't calibrate "values": you calibrate "instruments").
That said, pressure references here at work read 988.3 hPa, but my watch reads 989.2. Is it possible to calibrate this?
Thank you
