I can't sync my Garmin Delta Tactix to my Samsung Buds Live... Any help? I think it is why I can't install in the watch the app Samsung Wear.
Opening the case of the buds and leaving them in the case should be enough to make them visible for pairing, so long as they are not connected to something else at the same time.
If that doesn't work…
I paired Buds Live, Pro and original yesterday with my 6X Pro Solar running firmware 16.60. No special steps required except to turn off Bluetooth on phone and tablet so that there was no other connection…
Thanks you, I repeated that like 20 times and finally it got paired! Thanks again! (I was crazy checking for tutorials hehehe)
I paired Buds Live, Pro and original yesterday with my 6X Pro Solar running firmware 16.60. No special steps required except to turn off Bluetooth on phone and tablet so that there was no other connection made. Other pairing is OK, but not a connection when you are trying to pair a new device.
No apps required. It's just like pairing any other sensor/accessory.
Any advice about Buds? Buds were on the box? On Ur ear? I don't know when Buds Live are available to new cconnection
If that doesn't work then force pairing mode by putting the buds into your ears and long pressing both buds until you hear the sound to indicate pairing mode.
Connected my 'buds' following your instructions after a couple of hours of floundering around trying on my own, so many thanks very helpful.
