Recap:
- Device uses built-in barometer to measure pressure, from which it can reasonably accurately measure altitude gain/loss.. or a weather system change (the trick being to differentiate between the two).
- Calibrating at the start of a run (as an example), assuming accurate, would give the correct starting elevation (less important to most of us) and from there the barometer records relative altitude gain/loss (more important to most of us).
- Setting the device to continuously auto-calibrate during activities does just that, the purpose being to keep in check any pressure changes/drift not due to altitude change but weather systems, so should improve accuracy.. but again relies on the auto-calibration getting good values.
- When manually calibrating, you can either enter the current altitude (most accurate if you know this), use DEM (built into the maps, requires a 2D GPS fix, generally will be accurate although averaged out over a small area) or use GPS (requires good 3D GPS fix, has the potential to be most accurate for your exact location, as well as the potential to be most inaccurate due to GPS errors!).
- While pressure changes due to weather systems can occur anywhere anytime, the likelihood of this is obviously reduced on say a 5-10km looped run around a park (20-50 minutes) vs. a point-to-point ultra trail run lasting 7+ hours.
Questions:
- When auto-calibration is set, either “once at start” or “continuously”, is it the DEM or GPS method that is used?
- Also when the GPS method is used, is DEM referred to in order to filter out obvious outlier readings?
- Is the time elapsed time/distance from start taken into account at all when auto-calibration is set (my "short run round a field" vs "long ultra marathon" point)? Or is this something the user should take into consideration when setting up their watch / before the start of specific activities?
- Finally, how does the “Not during activities” auto-calibration work? A lot of this time the watch might be indoors, therefore without being able to get a GPS fix..?
TIA. :)
