Has anyone found an alternative spring bar that has the stock Garmin large diameter ends with a smaller diameter tube section?
Or at least one with a much better lug/pin fit than a typical spring bar would offer?
I have several bands I'd like to use with my F6, most notable is the excellent Luminox carbon link bracelet, problem is the fatter Garmin pin won't fit through the hole in the end link.
I could use a normal size spring bar, but I don't trust them fitting sloppily in the Garmin's composite lugs.
I'm trying to get away from the Quickfit ends, they don't wrap over my wrist bone very well, if it did I'd probably just get the vented Ti DLC bracelet and move on... so I need a better pin option, or to locate a standard-link carbon or DLC coated Ti option with Garmin's large spring bar holes.
Any ideas?
