Hey, hello everyone, one question: what is the "A6/B0" in the clockface of my Fenix 6 pro solar?
Is it related to weather conditions?
Thank you!
Thank you!
I think it is highest/lowest temperature from the weather widget (phone /gcm must be connected).
Uhm, how is it possible if the current temperature is 12° (as in my case)? Thank you!
Which temperature does the weather widget show? The weather station the weather is taken from, is often some (more) kilometers away from your location, so the weather maybe does not match...
Weather = 11
Temperature = 26
Temperature = 26
Is that watch temperature? On my watch the English equivalent is H 18 /L 12 and Now 13. However, if I bring up the Temperature widget it's 29. This is well documented. It's because the temperature is taken from the sensor in the watch, which is of course affected by body heat.
If you are going to push back against that, please read through the other forum posts about this to better understand why.
O A é de alto, o B é de baixo.
Agora é estranho pois são valores baixos. Pode ser que o o local onde o fenix está a ir buscar as temperaturas extremas esteja errado. O que diz o widget de temperatura?
IT's the FORECAST weather. Forecasts can of course be wrong, but blame the forecasting service, not the watch.
If DOM is Domenica then I’d assume A/B being Alta and Bassa. In terms of highest and lowest temperatures predicted for today.
