I got a Fenix Pro and this is written based on the last Beta release 15.71 but I have noticed it for a year now.
When the Music Player Control is linked through Blue Tooth to my phones (It has happen before on a Samsung S9 Plus and now on a Samsung S20 Plus) the battery usage goes x10 !! If I got 0,1%/hour, it the goes to 1.5%/hour just by listening to music/podcast on my phone.
The BUG is that the Music Player Control is also losing the connection (no more name of the file and control) if I put it in on Pause.
So, in my case, this is a Blue Tooth issue on a BUGGY Musical Widget for now a year.
It is easy to notice the battery drain when the music widget is "on", as this last 15.71 BETA release is especially excellent on battery.
Now 09:00 I got (with all on) a 0.4%/hour and I have lost 6.0% in 16 hours (since yesterday 17:00)
The projection is 13 days for Garmin and 16,3 days for Battery Gauge.
Also: Blue tooth linked to the phone for weather or any messaging DOES NOT drain the battery in my case.
You can notice a little higher consumption if the phone is far away (in another room) from the Fenix.
ONLY the Music Player Control (when in use) creates that particular drain in idle mode.
Yesterday I have only checked that the title of the track I was listening was displayed on my Fenix. That's all !
I have even not used the Fenix to adjust the Volume or anything.
And I have found (again) the consumption was jumping to 1.5%/hour instead of its "normal" 0.1% to 0.3% idle juice consumption.
Your experience may vary but this is mine.
I can shut off BT with its own widget: the battery life got 7 bonus days on the display.
My main move is using the battery saver widget I have set to my need to record my sleeps.
In either case it stops the leaking when I don't need to get notification or weather updates.
I have written to the Beta Team.
Who else has noticed particular drain linked to Music Control uses ?
