Just saw the new Garmin in utero watch.
The ultrafit strap is pretty sweet ..where is it available
Garmin website, I think it's $50.
Edit: I could have sworn I read/heard somewhere that it was available on the Garmin site for $50, but I can't seem to find it there, nor can I find where I heard/read it...
Edit 2: gaijin found it, see his link below
I am looking at the 22 mm quickfit nylon and they are $200. Is taht insane ?
How is it attached? During an Amniocentesis?
It is indeed available for order on the Garmin site. Click here: 26mm Nylon UltraFit Straps
HTH
Ah hah! I thought I was going crazy for a minute, couldn't find it anywhere. Yep, that's the one, $50 USD. Thanks!
Only 26mm. Looks like it would not work with Fenix quickfit though. Does it loop around the lugs? I cannot tell.
Makes sense since the Enduro only comes as 26mm. Maybe they will make other sizes available for that strap later, but it might be a while.
I can't tell how it installs to the watch, either.
Looks like it’s the same as the Tickr Fit HRM. There’s Velcro at both ends. You loop one end under one the pins and stick the Velcro to the strap, then do the same with the other end on the other pin. But you don’t press the Velcro down until you’ve cinched the watch down.
https://ify.coros.com/products/coros-vertix-nylon-quick-release-band-22mm
Does this fit the 22mm Fenix's??
