Why doesn't the Fenix Pro notify me in some way when my battery is getting low? I didn't spend $1300 Canadian on a watch that does not give me a heads up as to when I should charge it. Has anyone found a way to have it notify?
You're too kind. I'd just say RTFM:
The battery saver feature allows you to quickly adjust system settings to extend battery life in watch mode.
You can turn on the battery saver feature from the controls menu (Viewing the Controls Menu).
Select Watch Face to enable a low-power watch face that updates once per minute.
Select Music to disable listening to music from your watch.
Select Phone to disconnect your paired phone.
Select Wi-Fi to disconnect from a Wi‑Fi® network.
Select Activity Tracking to turn off all-day activity tracking, including steps, floors climbed, intensity minutes, sleep tracking, and Move IQ events.
Select Wrist Heart Rate to turn off the wrist heart rate monitor.
Select Backlight to disable the automatic backlight.
The watch displays the hours of battery life gained with each setting change.
