I use the Strength app to monitor and record all my gym sessions. In general this works well. But totally fails to record any activity when I am using leg machines such as Leg press and leg curl. Is there a way to be able to monitor these? Thanks.
Use Lap button to switch between sets and rest, then update reps set count on post-set rep count screen as usual. Upon syncing to Connect, update exercises and weights in the exercise list.
Alternatively, if the workout you do is the same, you could create a custom strength workout. This way both the exercises and intended weights will be prefilled, and you only need to update rep counts.
I like the idea of creating a custom workout; one for leg press and one for leg curls How do I set that up?
Training -> Workouts in either mobile or web Garmin Connect.
Got it. Thanks.
