Anyone know if its possible? I think that it would be a nice feature to see progress at decimal level so we can easier track the improvements in our training.
It is available in the FIT file and one free platform that shows it with decimals is Runalyze:
So many are defending the lack of visibility of decimals in VO2 max. Change it ! You are all wrong. Here's why:
The categories measure to 1 decimal place yet the result does not! Therefore this is…
2 decimal points is probably a false level of precision, but 1 decimal place would at least give some good context if you were bouncing between say, 48.4 and 48.6 from run to run.
Do you know what the data field is called in the .FIT files? And how the data is stored in the files? Maybe Runalyze and Strava calculates the VO2 based on heart bpm etc.
I will have to check that when I get home but it is in the file. Runalyze do a calculation as well but that gives a completely different value. The values I marked in the screenshot is from Garmin and taken from the file.
Do you know your weight to 2 decimal places?
VO2max = ml/min/kg
How often do you weigh yourself? Every time before a workout? Naked? How long does it take between weighing in and starting a workout? 10-20-30 minutes? Do you think your weight has not changed during this time? Don't do ***. These numbers are nonsense anyway.
Quite a lot of what's in the FIT files isn't in the FIT-SDK documentation and isn't converted by the FIT-CSV tools either. VO2max shows up in two or three places, often as MET which needs scaling to VO2max.
You might find a read of this file interesting
