How to track distance in an endless pool?
The pool /open water is no good
Create a Custom app in your watch (e.g. "Infinite pool") based on the Open water app.
In this new app, go to its settings and set GPS to "Off". Similar to the treadmill app,
it will measure your total strokes, time and a estimate of the distance. If you know the average length
of your stroke you can make a more precise estimate, and if the endless pool has any function to
measure the distance, you can enter that data manually.
If you never do real open water swimming, you can directly disable the GPS in the default app.
The Pool app detects your turns and multiplies the lap by the length of the pool, won't be of use here.
Hi,
Go to endless pool.
Go into setting and disable the GPS...
That's it...
Then start to swim, you will see
Has Garmin created a setting for an Endless Spa?
