Can't add revolut card to Garmin Connect (5 minutes ago I paid with the old revolut card)
Hi, I erased the revolut working card to use a new one, but when I tried to add this new Revolut Card garmin connect says that this bank is not working with GPAY. I erased cache and data, install and reinstall Garmin Connect, join and un-join the fenix 6 pro, but always the same message.
Thanks
  • Hi I can confirm this works. I deleted my old revolut card for a special edition one and it wouldn't accept it. I contacted revolut in the app chat and asked them to create a virtual mastercard. They did it straight away and Garmin pay was the set up when I added the virtual card.
  • Thanks for the tip, just did the same, got revolut help service to issue virtual MasterCard and works fine. Shame that revolut and garmin help do not know to advise this but all sorted now.
  • Same issue. Solved with a Virtual MasterCard activated by Revolut Support.
  • But old Revolut Card will stop working soon. And new Revolut cards won't work at all with Garminpay ?
  • My Revolut virtual Master Card issued manually by a support agent is valid till 2027 and unlike the physical card which BIN identifies the card in the UK, has another BIN for Spain. Probably this card is working for that reason. I guess the solution so far is to reach out to Revolut support asking for a virtual card corresponding to your country. Then it should work.
