Anyone else seeing this? I have already tried doing a soft reset but no luck.. I own a Fenix 6X Pro Solar.
I have the same watch and the same issue. After returning from a trip to New Zealand, the location is stuck in Auckland, and the temp at 50 f.
Have you got a GPS connection at your new location? That's often the cause.
The temperature sensor measures the temperature of the skin surface, what does this have to do with the GPS position?
Yes, I have used the GPS since returning with no change.
Have you checked if Connect app has permission to access location data on the phone? Sometimes permissions are revoked
... and besides the permissions, also check the settings in Garmin Connect Mobile menu » Settings » User Settings » Weather Location and make sure it is either set to "Use Phone Location" or to the right Fixed Location. More about it here: Questions About the Weather Widget on a Garmin Device | Garmin Customer Support. If everything seems to be set right, then force-stop the app, restart it, and restart also your watch in the same time.
