Is there a way to import a GPX file to my watch to use as a map in an activity? I'm essentially looking to make custom maps to use while cycling/running/hiking so that I can use the turn by turn directions.
Best way I've found to do custom routes with good TBT is use PlotARoute to create a FIT file of the route, download it to the watch in /GARMIN/NEWFILES and it appears as a route
Open it with Garmin connect on your mobile, then you can send it to your watch. You'll find it as a route on your watch.
