On my f6 pro the gesture seems to be broken.
Sometimes works but if the watch go in "power saving mode" i haveto push a button to have the light back. Can't accept this on a 1000 euros device. Tried all the options. No results
Because it's a power-saving feature to turn gesture backlight off in battery saver mode. The whole point of battery saver mode is to turn off all unnecessary battery-draining features. If it bothers you, you can edit Battery Saver mode in the Power Manager and change the backlight setting to "Don't change". For a 1000 euros device, it's worthwhile to browse through the settings menu a little.
Thx i'll try
Tried, but is so irregular
Battery saving mode & backlight gesture not working despite the "don't change" mode is activated. This happend only when upgrade to firmware 12. In firmware v.9 there is not such a problem ! Backlight settings "don't change" and "light off" make no difference when "power saving" is activated. I think is a BUG of v.12 firmware.
Same here on firmware 12.20. Backlight is set to turn on by gesture in all modes and to "don't change" in power saving but gesture does not work, when power saving is activated.
