I am trying to locate the temperature reading on my fenix 6x pro solar but cannot
Temperature of what? From the weather info from the internet, or from the watch sensor, or a Tempe sensor?
There's a Temperature widget you can add to your widgets, that shows the temperature from a Tempe sensor. You can also add a temperature datafield to your activities that shows the temperature of a Tempe sensor (if you have one) or the watch's internal sensor (if you don't)
the watch temperature. i know there was something you can set temperature to compensate for body heat etc but cannot find anymore
You cannot set any of the temperatures, only view the data.
Some CIQ watchfaces have a temperature offset setting, but FYI it doesn't work well. Body heat compensation is a lot more complicated than just a simple temperature offset. If accurate temperature readings are needed, you have to use an off-body sensor like the Tempe sensor.
With this widget, you can see the internal temp as well as a tempe if you have one paired/connected.
https://apps.garmin.com/en-US/apps/17580ca9-816e-4203-a6a5-002eb543c04a
