Skin burn
Hi all
I’m getting skin burns exactly where the led lights sit on my  wrists. I see I’m not the only one.. rather worried this can cause further problem. I have a fenix 6x Saphire
  • The OHR lights/sensors are encased in an epoxy resin - perhaps you have an allergy to that?
    The other possibility is that the sensor protrusion is irritating your skin.
    You could try putting a small piece of clear tape over the sensor for a few days and see if that helps - if so, then I would bet on it being an epoxy allergy, which means Garmin's whole line of products is going to cause the same issue and there isn't really a solution. If not, then the protrusion is probably just irritating your skin, in which case the only solution is to wear the watch looser. Note that the tape isn't a long-term solution to the problem, since OHR sensor likely won't work right through the tape.
    A 3rd possibility is that the watch and/or the skin underneath it aren't getting cleaned with soap often enough, and bacteria or fungus are becoming an issue, but I think this is unlikely in your case since it seems to only affect the exact area where the sensor is. In any case, it's a good idea to wash the watch with liquid dish soap (I like to dilute it with water first) to rule that out as the problem.
  • Yeah, the LED energy levels are nowhere near enough to be problematic - that is almost certainly either a bacterial/fungal issue or an epoxy allergy
    0 Former Member in reply to Ɛpsilon
    Thanks for the reply’s.
    Interesting threads. Definitely a burn on the skin. If it was fungal would be in another area as other threads demonstrate. This is directly under the led lights
    forums.garmin.com/.../burn-skin-from-optical-sensor
  • There are two rectangular shaped leds so if that is a burn, why shape is circular and much bigger than actual led-lights?
    0 Former Member in reply to jarivee
  • The sensor is raised and in closer contact with your skin. It is also furthest from the edge, and thus has less opportunity to "breathe".
    Wearing it firmly and 24/7, it's likely a skin irritation. Wash the watch regularly (especially after a sweaty run), and take it off overnight (or switch it to your other wrist if you still want HR & sleep data).
    I had skin irritation with my Fenix 5s plus also first when using but irritations disappeared after i started to keep the strap loose on daily use. Switch the watch to right hand always for the night. And wash it with water always after I shower my self (I take my watch off while showering) Also wash the watch with soap time to time.
    0 Former Member in reply to C.sco
    I was getting a  ark but took to washing regularly  around the area and also cleaned the back of watch , no further problems ,  my son also has same watch never had issues ,he doesn't wear watch at night and also loser than i do
    This is my 2nd fennix and sons 3rd
    I had exact same thing only on a different part of wrist caused by strap  Its contact dermatitis probably caused by wearing watch all the time.mines cleared up in a few days after not wearing the watch for s spell.
