How do you set incoming call vibration to continuous?
It would be nice if it keeps vibrating until I accepted/rejected the call instead of only vibrates two times.
Is it configurable?
Thanks
  • How do we file a bug request to get this fixed?
  • Garmin, please do it. I know many people who don't want to buy any Garmin watch because of vibration issue. Just make new firmware
  • Is there any official reply on this? A much needed feature
  • No
    But you can make a suggestion. Google ‘Garmin Ideas and suggestions’
  • I will thanks for that @phlipshambrook, but I think if they have not fixed this by now then I doubt they are interested.
    In the meantime, I have come up with a workaround using the Android App 'Tasker'
    I have set up a rule that will trigger a series of repeated notifications that will vibrate the watch in the event of an incoming call.
    Here are the settings for a workaround for anyone interested, I've tried to make this as user friendly as possible so reach out if you need help:
    1. Download and install tasker from the Google Play store
    2. In the Profiles tab, add a new profile called 'Incoming Call' using: Event > Phone > Phone Ringing. Here you have the option of specifying a caller/contact that you would like this to run for when they call. I left it blank because I need all calls notified. Then press the back arrow.
    3. When Prompted for a New Task, add: 'Task' > 'Wait'. Set for 2 seconds and hit the back arrow
    4. Add another task (the big + button bottom right), 'Variables' > 'Variable Set'. Under 'Name', in capitals write NOTIFYAMOUNT. under 'To' write       11 (this is how many times the watch will vibrate after the initial Incoming Call double vibrate so choose a desired number)  (then tap back       arrow)
    5. Add another task 'Alert' > 'Notify'. Under 'Title' and 'Text' write Incoming Call (or whatever you want the watch to read when a call is coming in)     Under  'Category', tap the '=>' icon (next to search) scroll down and select 'Caller Name (In)' (then hit back arrow)
    6.Add a task 'Variables' > 'Variable Subtract'. Under name, tap the => icon and select your %NOTIFYAMOUNT variable you have defined in step     4. Make the value 1 (then tap back arrow)
    7. Add a task 'Task' > 'Wait'. Make this 3 seconds. (tap back arrow)
    8. Add a task 'Alert' > 'Notify Cancel' (tap back arrow)
    9. Add a task 'Task' > 'Goto'. Configure as follows:
        Type = Action Number
        Number = 3
        For 'If', tap the => button and select your %NOTIFYAMOUNT variable. you will see an icon with a '~' (tilde) symbol. Tap this and select                  'Maths   >  Greater Than'. For the number, make this '0' so it should look like: %NOTIFYAMOUNT > 0
    Keep hitting back out of the app, and test.
    This is great because now when I am on call the watch will vibrate more than twice, hopefully waking only me and not my family when my phone rings.
  • Thanks for the tasker tip!  (I'm not sure why I never thought of using Tasker as a way to fix this bug in the Garmin software.)
    I tested you solution and It worked for me.
    The one additional step I needed to add was to make sure to enable notifications from Tasker.
  • is it possible that there was a change in how Garmin phone call notifications are handled on the watch?
    i tried the above on Vivoactive 4s, but it looks like that as long the phone call information is displayed (with a selection of options to answer, decline or text a short reply) the notifications are not appearing and therefore no additional vibration. At the same time I can see the procedure is running on the phone.
    when I do a test in tasker - without the actual phone call as trigger, the notifications are feeding into the watch correctly (all 11).
  • Great idea ! Worked for me as well but I did a small improvement because this way it continues to create notifications even after the call is declinded or answered.
    1. Create profile -> Event -> Phone Offhook -> Back - > New Task -> + sign -> Variables -> Variable Set. Name: %ACTIVERING; To: 0
    2. Create profile -> Event -> Phone Idle -> Back - > New Task -> + sign -> Variables -> Variable Set. Name: %ACTIVERING; To: 0
    3. In the task from the steps from :
     3.1 + sign -> Variables -> Variable Set. Name: %ACTIVERING; To: 1
     3.2 Move the above new step to step 2
     3.3 Edit in the last step "Number" value from 3 to 4. In the If condition -> + sign -> in the first filed of the new line on the left add %ACTIVERING -> click on ~ -> Select "Equals" -> Add "1" in the right
