AirPod Pro Problem
Hi,
I have 2 sets of AirPods Pro paired with a fénix 6 pro, but after the last update to r9.0 the AirPods no longer connect to the phone.
When I tried to delete them I was no longer able to pair them again. Since the AirPods work fine with iPhone and other players its a GARMIN problem.
The weird thing is that when is stops looking for the headphones it says “no sensor found”.
Anyone with this problem?
Thanks
  • Make sure none of your other devices are in range of the AirPods or they will capture the BT signal.
    0 Former Member in reply to GBru
    They're not. And both iPad and iPhone have Bluetooth disabled.
    I put the watch to search for headphones and the error message it gives me is of sensors "no sensors found". This just happened after the latest update form Garmin to 9.0
    Solved it. I had to remove both sets of Airpods from the Apple ID Account, then pairing them with the Garmin watch.
    Then I could paired them again with iPhone and iPad and everything worked again.
    Thanks Garmin for always changing your firmware and always leaving bugs there!!
  • remove from apple id account?  How did you do this?  forget device on iphone/ipad?
