I have switched off backlight everywhere in settings. When I press the start button before starting an activity the backlight turns on. If for some reason it takes some time before I actually start the activity the backlight stays on. I have to press Light manually to turn it off. Even then if I go to settings of the activity the backlight again turns on while I press buttons. Is this a bug? I don't want the backlight to turn on at all. I can't be sure if the backlight is on or off under the sun and it uses too much battery if I forget it for long time before I start the activity. If it takes some time to change some settings backlight stays on using more battery for no reason. Pressing any buttons to browse settings, courses, maps it turns on the backlight. I can't be sure if it's on or off under the sun. Please fix this. If I need backlight anyway I can press Light button.
