I rarely wear headphones while running. On Apple Watch, audio cues from Strava were played out loud through the loudspeaker.
Is this possible on Fenix 6X?
Moving post to the fēnix 6 series forum.
Thanks. Noob error.
Er, there is no speaker in a Fenix6
If you carry your connected phone with you they will play out loud through the phone if you don't have headphones connected.
Technically there is, but it's sealed inside a 100m-rated waterproof case, so the only thing it works for is high-pitched beeps. Voice prompts would be so muffled/garbled you wouldn't be able to hear or understand it.
AW gets around that issue by having the speaker outside the waterproof casing, exposed to the elements (which allows for higher-quality audio but introduces a whole host of other issues that Garmin wanted to avoid - like a reduced waterproofing rating, and a speaker that fills with water that you have to go through a water ejection process to remove)
Thanks. Phone always in belt/pouch!
All good points. Thanks for the reply.
