No more activity map view after update
Hi Guys,
So you probably know that when wanted to look at your last activity on your device after finishing it you could see a red line beeing the gps track on the main activity screen. When you pressed down you could choose "all statistics", "training effect" and so on AND you could choose "Map" and look at the the gps track on the map.
So my problem is that the gps line on the main screen is no longer there, and the "Map" option is also missing. Did anybody else noticed that after the update to s/w 8.10? This is missing for all activities that you want to preview on the device. Any help on that?
Thanks in advance.
  • hi! i can tell you that my last activity before quarantine (brief run) shows me map and the red track!
  • Looks like the settings have changed with the latest beta but I do know I was seeing everything I expected to see with 8.10
    Three screenshots of last evening's activity:
    As you an see there's been a change in how the additional options are displayed. There's a white bar by the top right button indicating that you press it for more options.
     When you do you end up with this
    0 Former Member over 5 years ago
    Ok, so it seems that that this issue is directly connected to the fact that I had my watch replaced on warranty. When i got the new one it synced old workouts via connect and indeed they had no map visible. Later in the evening I've done a new workout with the new device and the map is there as it should be. I've confirmed this with another guy that had the same issue.
    So the case is that if you sync old activities on the new device it won't show the map but the new ones will. Still a small bug for me though.
  • That will be the case. If the activities have come back after PhysioTrueup then you only get the data and not the maps.
