Tactix/Fenix + Treadmill + Stryd. Any Way to Record VO2 Max?
i have a tactix delta paired to a polar hr chest strap and a stryd foot pod. i run on a treadmill using the "treadmill run" profile. i have yet to see any mention of VO2 max since owning the watch, though i do see the following training effect data from each run:
primary benefit
anaerobic score
aerobic score
exercise load
so my question is, how can i find out my VO2 max?  i do NOT run outside (100% treadmill), and my main sport is mountain biking (but without a power meter). i've read that it IS somehow possible for the device to use the stryd meter to calculate this, but here's where i get lost. i find this subject to be incredibly confusing, but here's what i've gathered so far from my research (correct any errors please):
1. there are 2 ways to have the watch calculate VO2 max: either by running outdoors for 10 minutes with a GPS lock or cycling with a power meter. it seems there may be a third way by just walking (making sure you're at 70% max hr), but that may be limited to vivoactive? not sure about option 3 for the tactix/fenix line
2. the "treadmill run" and "trail run" profiles will not calculate vo2 max regardless of anything else. you can't use them as they disable VO2 calculations for some reason
3. it "may" be possible to use the "run" profile, disable GPS and use the stryd and the watch will calculate it, but this may interfere with other numbers/metrics. research is VERY unclear on this point
4. buy a compatible power meter (NOT a speed / cadence sensor - these won't work to calculate VO2 max) and have the garmin calculate while mountain biking
5. failing everything else, either find a way to run outside once in a while or just calculate your VO2 max manually using one of the hundreds of online calculating tools available
any help making sense of all this would be greatly appreciated
  • No other way to calculate VO2 Max. The FirstBeat VO2 Max calculation requires outdoors running or biking on roads. Mountain biking, indoor training bikes, and treadmills won't give you a VO2 Max result.
    You could try to "trick" it by using an outdoor running profile while on a treadmill, but the results won't be accurate because it wasn't designed for that.
    In order to do what you're wanting to do, FirstBeat would need to invent a new algorithm that doesn't currently exist.
    I think that's incorrect.  I am connecting my fenix 6x Pro to my chest HRM and the ANT+ Power and Speed/Cadence output from my Concept 2 BikeErg (i.e. indoor training bike).  Among the various metrics tracked and recorded is VO2 Max.  I've been doing this for a while and the VO2 Max data seem pretty reliable to me. I am using the Bike Indoor App.
    HTH
    Not quite. It requires outside road running (not trail running) or cycling with a power meter (indoor and MTB qualify if they have a PM).
  • I would try to make a copy of the standard outdoor run activity, disable GPS and use Stryd for speed and distance. It sounds weird if the VO2 calculation really checks for GPS lock, it only requires heart rate, speed, distance and perhaps elevation.
