my Fenix is not assigned a drive letter by Windows. Therefore i cannot insert files.
The error message in Windows Device Manager reads Device not migrated.
can someone help me there?
The Fenix 6X will NOT be assigned a drive letter on Windows, it shows up (quite correctly) as an MTP device (which it is). Have you tried rebooting the Windows PC (which version of Windows are you using?). Have you tried another USB port and/or cable?
yes I have already tried everything.
I am using Windows 10.
sounds like a problem on your windows
tried to rollback the device driver ?
how did you setup usb mode on your F6X
happy & safe sporting
rollback does windows not allow.
I tried both modes.
Garmin mode won’t work on Windows, only MTP mode works. If the other suggestions haven’t solved the issue, then you better contact GARMIN support...
ok thanks
post a screenshot of your windows device manager with the fault
post the windows 10 version number
try this to repair your windows ... multiple-ways-to-fix-device-not-migrated-error
this is the complete text in German
Das Gerät USB\VID_091E&PID_4CDB\0000c5c026d5 wurde aufgrund einer teilweisen oder mehrdeutigen Übereinstimmung nicht migriert.
ID der letzten Geräteinstanz: USB\VID_091E&PID_296D\6&3a592d3c&0&3
Klassen-GUID: {36fc9e60-c465-11cf-8056-444553540000}
Speicherortpfad: PCIROOT(0)#PCI(1400)#USBROOT(0)#USB(9)#USB(3)
Migrationsrang: 0xF000FFFFFFFF0113
Vorhanden: false
Status: 0xC0000719
