Backlight was working fine. Updated to 6.10 and now it won’t come on.
anyone have a solution?
Check your backlight settings
I’ve tried various settings including turning on gesture control. Nothing brings it on. Was working fine previously
I have it working again - there must be a software bug.
It won't work until something triggers it to automatically come on - in this case I was downloading a spotify playlist. Doing so triggered the light to come on. Now works again as normal, but this isn't the first time I've had the problem.
Garmin - please fix!! Too expensive a watch for basics not to work!!
The pattern seems to be that after an activity (Pool swim, and indoor cycling) the backlight won't come on. If I use certain functions (spotify update action seems to work) they trigger the light to come on. From then on it works until I next do an activity.
Hello Garmin!!??
Hello Garmin!!??
Contact Garmin Support directly and log the issue you are having. You cannot expect them to deal with individual issues in a peer-to-peer forum.
Have you tried to perform a soft reset?
