Garmin Fenix 6 Pro - Heart rate drops to a low number in the middle of a workout - it start tracking ok and then suddenly goes down to 85-100 when it should be 150! Tried wearing the watch tighter, looser on the other hand. Same result. Any ideas?
Hi, it went up to 140 - stayed there for a few minutes and then suddenly dropped to 85 and then never went up beyond 100. I could barely breathe and it was still 100.
Here is the video. thats mine
The clock showed no more than 100 during the activity without a profile started. see what happens after the activity when I press the start button.
Best is to contact Garmin :
[email protected] and [email protected]
let you ad to the Ticket PSC-87166
Did it go up to 150 and then dropping down? Or doesn’t it reach the 150 ?
Does this happen when you start an activity profil for your workout? Or do you only look at the hr widget without starting an activity profil ?
I always use a profile - Floor Climb/Strength/Cardio
Ok. That is working good for me. I only have almost your problem, when i don’t start an profil. But in this case it will never reach higher hr.
This sucks. Even my Fitbit Charge 3 gave me stable readings. I also have a Vivosmart 4 that is fine. This expensive watch can't even do the basics!
Yes! I agree!
same behavior during spinning. after 30 mn, hr went from 140 to 70 and never went back up except if i started the activity.
I guess we got a lemon . Is there a fix for this in the works?
Yes. They are working since 4 month on a fix.
