Received v2.70 as an OTA update this morning.
Probably related to the sticky : https://forums.garmin.com/outdoor-recreation/outdoor-recreation/f/fenix-6-series/212256/my-garmin-fitness-device-is-taking-a-long-time-to-acquire-a-satellite-signal
I never had any issues before, so hopefully it stays that way
I received the update last night. Let's see if there is any impact on performance. Actually I had no issues with GPS performance.
I had the GPS fix issue. Received the update this morning. Just tested a bit and problems spear to be solved. Less than 10 sec to GPS fix and hiking track accuracy seemed okay. Happy again.
Interesting! Yes, it's probably related to that. No official announcement, and your post here is the first time anyone has mentioned it. Mine is still showing GPS 2.60, I'll check it again tomorrow.
Change Log
- Update almanac data to prevent long fix times.
Do you have a Fenix 6 series, as no notice of the update for F6?
still on v2.60
Yes, I have a fenix 6 pro, and this morning i got the gps update to v2.70
still on v2.60
It's common that Garmin pushes new releases in batches. Normally it takes a couple of days until all devices gets the new version.
For some reason it seems like I'm always in the last batch
Just received 2.70 for my Fenix 6 Pro.
Consider it as a good thing. If something goes wrong you probably won't be affected
