Sleep not being recorded.
I noticed for the past two days that Sleep tracking isn't being recorded.  Is anyone else noticing this problem?
I'm currently on 5.0 and Sensor Hub 3.10
Been loving my Fenix 6, but strange that this problem just popped up.
    0 Former Member over 5 years ago
    My Fenix 6x Sapphire is tracking 9 hours off sleep when laying on a table. Changed sleep time to 00.00 and wake up 00.01 now it tracks only 4 hour average on the table :). Full watch reset didn't helped and the beta also didn't changed anything so yours tracks no sleep my watch tracks sleep when it is not relevant :).
  • I’m on 5.1 on an APAC 6s Pro Sapphire and hasn’t recorded sleep for last 3 days. On Saturday when sleep stopped recording I had no WHR reading; tried taking off arm, and back on (sensor lights were working, and power down. Finally had WHR working after recording a walk activity.
    This seems related to battery saver on sleep, which I have only just enabled. Didn’t have sleep recording issues before this and wonder if this working as designed?
  • Which phone? Which OS? Are you seeing data on Garmin Connect interweb?
    FWIW, I have my F6 set to Battery Saver mode when sleeping and am seeing sleep data. This is with F6 pro sapphire on 5.75b (just updated to 5.76b).
  • iPhone 11 on 13.3. Web site says “UNMEASURABLE” and no sleep recorded last night. On 5.10 official as APAC device.
  • I have problem with sleep tracking but different kind.
    It seems there is bug somewhere for Sleep statistics. When I check sleep statistics immediately in the morning after I wake up I have there for example 53 minutes of deep sleep, and then when I check it later let's say during day or in the afternoon there is suddendly totaly different number like 13 minutes for deep sleep for the same night, this is happening on my Fenix 6 Sapphire + Iphone IOS Garmin connect application as well on my girlfriend's Fenix 6s Sapphire + Android Garmin connect application. Both watches are running beta 5.74 firmware but it was the same also on stock firmware.
    Coudl somebody confirm the same behavior?
    By the way I wanted to open this as separate topic on forum but it is not allowing me to post new thread everytime it is saying that I have reached limit despite I didn't created any thread in this forum yet. Do you know how to fix that?
    Last night I noticed I did get my Sleep recorded.  What I did was not schedule Battery Save via Bedtime. It appears Battery Save via Bedtime is what is blocking your sleep from being tracked and/or recorded.
  • I suspected this was the case as you only get a very basic watch face, so presumably many other measurements are turned off to preserve the battery.
    I must admit I do like this battery saver option though as my battery life is now at 46% after full charge 5 days ago. I am not particularly bothered by sleep statistics as it always seems never enough! Slight smile
  •  Former Member
    Enabling Battery Saver mode during sleep time does not affect the recording of sleep providing WHR is on. Even if you choose to disconnect from the phone, the data is updated once the watch reconnects to the phone when you come out of Battery Saver.
    My Battery Saver mode kicks in at 21:30 and out at 05:30. This is last night's sleep (I had a lie-in this morning :-) ). You can also choose what is active or inactive in the Battery Saver mode so might be worth having a look in there and see what you might want. I have the following settings:
    • Watch Face - Low Power
    • Music - Disable
    • Phone - Disconnect
    • WiFi - Disconnect
    • Activity Tracking - Don't Change
    • Wrist Heart Rate - Dont' Change
    • Pulse Oximeter - Turn Off
    • Backlight - Turn Off
    0 Former Member over 5 years ago in reply to Former Member
    Mine is exactly the same.  Records deep sleep when on charge in the kitchen..  Perhaps it's recording its own sleep.!  Would of thought a simple fix e.g. No pulse being detected conclusion - watch not being worn.!
    Never had this issue on the vivoactive 3.
    My new Fenix 6s tracked for a few days then stopped. Rang Garmin reset watch now doesn’t track at all! Any ideas? Thanks
