Fenix 6 GPS accuracy + losing distance (vs FR945)
Hi,
I have the Fenix 6 pro and earned the FR945 before. I sold the FR945 to a friend who's often running with me.
I now made about 5 runs with him and we kinda often compare our stats and stuff. I noticed that when we run on the same course (in the range of 12-24km) he always tracks at least 200m more with the FR than me with my Fenix 6. So I compared the GPS tracks and looked for  found that differences.I found that the Fenix 6 is far more inaccurate and often off track by a couple (10-20m) when running in the forest (no trails just "normal" forest tracks). This improves slightly when running on normal roads without trees or sth. However it also happens very often that corners are cut or that the turn is indicated early than it really was, leading to the difference in total distance.
How can that be? I know that both GPS sensors are the same and I also checked with GLONASS and GALILEO without any improvements (the FR was using GPS only btw).
To clearify that I added two screenshots of the same track tracked with FR and Fenix 6. You clearly notice the bad tracking quality of the Fenix and also the difference in distance (compare the sign of KM11).
I simply want to know if that is normal for the Fenix 6 or if I can expect a fix for that or not..
Nico
