i need help, any idea for how to remove the blue pin point ? (it is used to be tactical set point for last activities)
I googled it for you. From Garmin Support (but this is for outdoor handheld device), but you can try it:
The blue push pin appears on an outdoor handheld when you navigate or use a route to a destination. The pin signifies that navigation point on the map page of the device. Once you choose to stop navigation, the pin will remain at that last location in case you want to resume navigation to that point again.
The only way to remove the push pin is to navigate to a different location or power the device off and back on.
thanks you for your great help,,,after power off,,,the pin is removed
