Pulse Oximeter how accurate is on F6x?
My father gor F6x and i looked at his sleep data. He has regulary oxy below 80% during sleep. Breath per minute around 6-7. Shoudl he consider visiting doctor or it is normal for old marathon man? He sometimes compeing about bad sleep, but i put this on his age.
    0 Former Member over 5 years ago
    6-7 breaths per minute seems worthy of a medical check.   My pulse ox is normally in the 93-98% range.  My BPM is 13-17.  I'm 54 and run ultra marathons with a RHR of 42 with dips into the high 30's.
    I can't speak to how accurate it is for any given watch or individual though. A cheap second opinion is a fingertip reader, they look to cost anywhere from $12 to $30 on amazon.
    0 Former Member over 5 years ago in reply to Former Member
    The ups and downs could be a sign of sleep apnea, it's pretty common.
  • To the question of accuracy :
    This is not a medical dispositive.
    About absolutes values measurement :
        Life conditions are considered to be compromised below 90.... under 85, that's a critical situation.
        So indeed, the value 80 is absolutely not realistic, and can be fully discarded as such.
    With that said, about relatives values :
       The device is so imprecise (get at your doctor, get a read with a real medical device, you'll see what I mean :) ), that small changes, can be discarded, and can't really be used.
    But, here, comparing 100% of saturations sometimes with 80% , is another story.
    It is a strong indicator, that something is going wrong :
    - The device is moving during the night, due to a specific position , or stuck not touching the wrist, due to the joints position.
    - apnea problem
    - very low cardiac frequency, due to another problem.
    So now about apnea more specificaly, there is common symptoms, often there :
    - frequent needs to go to the bathroom (2/3 times a night), even without drinking a lot of waters, most of the nights
    - feeling to be tired in the morning
    - memory loss
    So as you can see, nothing is evident, and jumping in the face, no real reason to worry, but it could be intesting to get advices of a real profesionnal :-)
    Hope this clarify a bit :)
