I'm a recent retired tech exec from Silicon Valley. I wanted to get the Fenix6 so that I don't need to wear chest strap while biking outside or in the gym, and be able to keep track with all of my gym activities without needing a cell phone and using multiple different apps while most of those don't even talk to each other or to Garmin Connect. I used to wear Fitbit HR device and found it to be so inaccurate, particularly when it comes to activities like BodyPump. For biking outdoors, I have Edge 520 and Polar strap as well as Garmin basic strap (which I hate due to the plastic). For indoor, I use Precor AMT elliptical machine, Concept2 rowing machine, Life Fitness treadmill, Life Fitness weight machines, ICG IC7 spin bike, and attend BodyPump classes.
I have compared the HR of Fenix6 versus both straps, and found them to match each other quite well, shockingly even for BodyPump it was good, with average HR are almost always identical, the peak HR are also very close. The Fenix6 lags behind slightly in both direction, but for all practical purposes, this is great news for HR Wrist base device.
Now the questions:
1) Calories count - it's always lower whether it's compared to Precor AMT (33%), Concept2 (15%), ICG IC7 (10%), Edge520 (15%), LF treadmill - this one is weird, 2 measurements, the one with higher HR and steep incline, almost identical calories, the one with lower incline and lower HR, both distance and calories are way off, so need more experiments. I was very careful making sure all personal data are correct in all machines, and these collected over multiple sessions. After HR, calorie burned is the most important data for me to collect, I based heavily on this to know when to eat again between exercises, and also to not over eat or under eat. I need to know why it's lower, or why it's correct and other machines are not. I tend to believe the other machines data because they have all the information, while Fenix6 does not.
2) Ant+ - although Garmin website says it supports LF, it doesn't (I tried multiple LF treadmills and ellipticals). I managed to get Concept2 to take HR from Fenix6. I got Fenix6 to receive cadence and power from IC7, but couldn't get Fenix6 HR to IC7 (but Polar chest strap is OK). I couldn't get Fenix6 HR to Precor AMT (although it took the Polar chest strap without issue). I was able to get Fenix6 to broadcast HR to Edge 520. Are there any plans to work with these companies so Fenix6 HR will work with all these machines? Without this Fenix6 working with these machines, my hope of getting rid of the strap is not possible.
3) Max heart rate - how do I supposed to set this? I know my max is well above 220-age, some times I can peak at almost 220, but what do I supposed to set here, and this number seems to affect many other items, including calories count, load, etc...
4) VO2max - this is actually very good, I got my FTP from IC7 and converted to VO2max, and I have been hovering right at that point and added a couple more points on extreme sessions.
5) Reps count - this is completely useless. I can understand it's not useful for BodyPump where there are many movements for same category of movements, but it is also useless when I did repetitive motion on the LF weight machines (12 different machines). What I don't understand is why even for squat, it's 5+ minutes of repetition of the same movement, albeit at different rates of up and down based on music, the count is way off. Can Garmin create an activity called BodyPump so that I at least can enter the weight I used for each exercise (there are 10 same sets every time, just different pace rhythm depending on the songs). I am not sure how weights used would affect calories count or not at all? Having said that, the calories count I have been getting is within the range of Les MiIls projected for male, but it's a wide range. The HR is lagging behind straps a little bit, but at least it didn't think that I was asleep like the Fitbit did after the ridiculous incredibly hard back routines with a bunch of clean and presses and power presses consecutively at high pace.
6) Navigation - another the reason I wanted to get the Fenix6 Pro, is to be able to navigate while walking on the streets, as I have spent many nights in different cities walking with frozen hands to navigate with cell phone, so I hope with this watch, I can actually walk with navigation and with gloves on. Unfortunately, the map data is way outdated, POI that have closed down for a couple of years still show up (if I walk half mile to reach some place that is closed for good, it would be very upsetting). Even with spelling POI, they don't work well if you don't remember the exact spelling. There is no way to get rid of the phone other than when you're in a pinch, just needed anything and willing to accept any destination in a foreign county, it may help but very limited. These are actually the same problems I had encountered with my other fancy Garmin for automobile navigation, I eventually dumped it in favor of the cell phone.
7) Music - Spotify works great, drains battery like crazy but it's OK since the spec said so. However, connection with blue tooth ear buds is horrible when walking out on the streets, but OK while in the gym on elliptical or treadmill. Why? I would assume that running would be even worst, correct? Are there recommended earbuds that would work well with Fenix6?
8) Temperature - I understand that body heat affects the temperature read out, but what is this temperature is supposed to tell me? The case temperature? The temperature to calculate hydration? All I know is it's drastically different than the Edge520 and the gym's thermostats. How do I supposed to interpret this? Can I truly rely on the hydration estimation if the temperature appeared to be so off?
9) Is there a way for Garmin Connect to collect Fitbit Aria2 scale data? I just got this Aria2 a few months ago, really don't want to get rid of it for a Garmin scale. This industry non-interoperability is just driving me nuts.
10) Pulse Ox - during the day is pretty accurate, but I am more interested in during sleep to see if I have sleep apnea, but the data is not correct depending on my sleep position and how my arm is contorted, folded, or whether I lay on top of it or not. So not a real solution. Don't know about the altitude adjustment yet, have to wait until skiing season.
So after a month, I can't get rid of chest strap, can't consolidate all exercise data into one platform, whether Fitbit, Strava or Garmin Connect, or anything else if anyone can suggest, can't get correct calories burned data, can't truly get rid of cell phone for navigation walking in foreign cities, don't need this for biking since I already have Edge520, can't truly listen to music walking on the streets, I don't hike, so why do I need this expensive watch?
I would appreciate any expert users here or Garmin experts to give me any comments/suggestions to any of the above topics.
