Cannot connect HRM Tri / HRM Run
Hi Folks -
Since couple of runs I noticed that I lost my running dynamics...so I checked the connection from my Fenix 6X Pro to my HRMs
I owned both HRM Tri & Run ... while checking the connection I noticed that they are just not connected to the watch.
I tried to remove my sensors from the list and adding them again .. no luck ... the watch is not detecting the HRMs (did try with both the HRM Tri & Run).
I tested those HRMs with my Garmin Edge 830 - they are working flawlessly.
I was running the last SW version - 4.30 ... so I updated to last beta software (4.63) .. same issue I'm not able to add back my sensors.
Does anybody have seen this issue before ?
Just wondering if it's SW or HW issue ...
Thanks in advance if you have any clue on this one.
Cheers.
  • For me tempe connects in a blink of an eye, as the hrm tri, but when i start an acitivy the hrm tri looks as is disconnected, sometime i have hearrate in some custom datafields but not the running dynamics, when i finish the acitivity i force the download of the hearrate data and at the end of the donwlod most of the times it pops up hrm connected.
    I will give the 9.95 a run. Thanks.
