I have a Fenix 6x sapphire. The website and connect app says I should have pulseox monitoring, the connect app says it’s all switched on, but the pulse ox widget doesn’t cost on my watch. How do I fix this?
You might need to add the Pulse Ox widget to your displayed widgets.
From the watch face, press the down button (bottom button on the left) repeatedly to scroll down until you reach the "Edit" screen and then press the top right button. This will take you to a widget edit screen. Scroll down on this list until you reach "+ Add" and press the top right button. Scroll down to Pulse Ox and press the top right button. Now, press the back button (bottom button on the right) two times which will take you back to the displayed widgets. You should now see the Pulse Ox widget.
Also, bear in mind that turning on the Pulse Ox settings (monitoring during the day and during sleep) will dramatically impact battery life. For most people, those settings should remain off. If you want to get an instant reading, just go to the Pulse Ox widget and wait a few seconds. A reading will automatically begin and will take 10 - 15 seconds to complete.
Thanks for the advice. Sadly I’ve tried that already. It doesn’t exist on the “add” panel at all.
Odd. What firmware are you running?
That either means you already have it active in the widget cycle or something is wrong.
Have you ensured in the settings that you actually have the Pulse Ox measuring turned on?
Have you read the manual - www8.garmin.com/.../GUID-4D425925-D4EE-4C26-B974-5375D0670860.html
