Multiple clocks as standard watch face
Dear friends,
is it possible to use the multiple clock widget face as the standard watch face?  Or can you advice me how to have a watchface where I can set and have at the same time the " Home time" and "Current location time"? I travel a lot so I would like to track home and local time at glance.
thanks
    It's not possible to use a widget as a watch face but several ConnectIQ watch faces support setting an alternate time zone. You could set the alternate to be your home time zone so that when you travel the main time would be wherever you are and the alternate would show your home time. Take a look through the ConnectIQ store to see if there is something that meets your needs.
  • thank you for reply. I have come to the same conclussion. However, this is so weird, and Garmin should add it to stock watchfaces as default
