Hi there,
is the only difference between the 6 pro and 6 x pro the screen size (1.3 vs 1.4)?
Or is there different functionality etc?
Thanks in advance
Hi there,
Thanks in advance
Quicker than describe here would be to take a look on Garmin web. All specs and differencies are there accurate and easy to find.
My wrist is also 175mm (just measured a moment ago). I've been wearing a 6X Pro Solar 24x7 for 17 months. Before that a 5X+ and before that a 3HR, all basically similar size/weight. I've never felt that…
Like available memory size?
Like this -
buy.garmin.com/.../compareResult.ep
Seems to be mainly size, and with that a bigger/better battery?
not to forget the 6 vs 8 datafields
www.dcrainmaker.com garmin-fenix6-pro-solar-series-review whats-new
www.dcrainmaker.com garmin-fenix6-pro-solar-series-review sports-usage
happy & safe sporting
I feel like, at some point, someone will just write an app to make 8 data fields available in the same format for the Fenix 6. There's already other apps that have lots of data fields.
Those already exist to some extend (basically they cheat by making a single datafield that has 8 sub-datafields, which can be customized in the datafield settings in the CIQ app), but the problem is they're not very customizable. They aren't nearly as flexible as the native 8-field watchfaces on the 6x. Not even close. And they don't allow you to use the nifty garmin graphical datafields.
But ya, other than 8 datafields, 50% bigger battery, and 16% bigger screen size and resolution, there's not really any other difference that I'm aware of.
anyone who has 6x, what is the feedback about the watch size vs various sports that implies some wrist twist, or at night in sleep ? Is it comfy or too big ? My wrist is 175 mm. Thanks.
My wrist is also 175mm (just measured a moment ago). I've been wearing a 6X Pro Solar 24x7 for 17 months. Before that a 5X+ and before that a 3HR, all basically similar size/weight. I've never felt that the watch is too big or heavy for daily life, running, cycling and sleeping.
I've worn much heavier, if not bulkier, watches before that, with full steel bodies and bracelets. It's something you get quite used to and is a complete non issue, in my opinion.
I'm thinking to change from a Forerunner 935, and struggling to choose between 6 pro and 6X pro.
I guess I'm gonna go for the big one, the extended battery being a big plus.
Thanks for your answer.
Best regards,
D.
