fenix 6x sapphire
edge 830
My indoor cardio workouts are done on an Air-Dyne Pro/AD-7, which doesn't have the capability to transmit the workout data (HR, speed, cadence, ET, distance or power). The only sensor currently being used is with the fenix is HR chest strap.
The workouts only demonstrate aerobic effect, even though all display as threshold workouts, today aerobic effect 3.9 with anaerobic effect 0.0 despite 22% in HR Zone 5 and 65% in Zone 4. The HR zones on both the fenix and edge are based on LTHR, which for me is right at 90% of the estimated max HR of 220 - age.
Road bike rides always list an anaerobic effect, even though the time spent in HR Zone 5 is less than during the shorter cardio workouts. This occurred even before I installed Assioma power meter pedals about 2 weeks ago, when only HR, speed and cadence were available.
I found an app for the fenix (Spin Tracker) that can estimate speed if cadence is known by putting gear ratio and wheel diameter in settings. My Garmin cadence sensor could be used on the Air-Dyne, since no longer used on the road bike because the power meter pedals supply cadence data.
Schwinn tech support wasn't able to provide the numbers they use to calculate speed, so I'll have to determine them the hard way by observation. The user manual for Spin Tracker indicates "Note: Garmin does not always show the IQ fields. I can’t do anything about it. ". Not clear whether they mean no data fields other than cadence would be saved unless both speed and cadence sensors are present, or whether the calculated speed and distance are also saved.
Has anyone used Spin Tracker on a spin bike or Air-Dyne that can clarify this?
